Depends what you want it for... Granted you can make any setup beast for anything but specifically...
S/c tvs - Drag
Turbo - Dyno and highway
Procharger - Dyno - dragish and highway
Procharger needs to be checked up on and watched avidly
s/c you can just trow on and not worry about
Turbo can be a hassle and a half
Procharger you make power from power. belt driven
S/c You make powere from power. belt driven
Turbo you make power from exhaust so essentially power from nothing.
You have to figure out what you want to do, the numbers you want and how often you want to be doing check ups...
Nothing is perfect but you have to see what best fits you...
Not sure how Procharger got its own category of forced induction. Let's review there are:
* centrifugal superchargers - these are compressors that generate airflow on the basis of centrifugal acceleration and therefore the airflow comes from speed. they are driven off of the engine crank shaft and therefore their speed is tied directly with engine RPM's. They also require power/energy from the crank to drive it. Some common kits out there are Vortech, Paxton, Powerdyne, Procharger
* positive displacement superchargers - these compressors move a fixed volume of air with each revolution. the compression of air (and therefore the density/mass flow) that results is from the greater volume of air that the supercharger is moving relative to the volume of air that the engine is moving (engine is the restriction). as a result, the compression of air happens at almost any compressor speed. they are driven off of the engine crank shaft and therefore their speed is tied directly with engine RPM's. They also require power/energy from the crank to drive it. Some common kits out there are Kenne Bell, Whipple, Eaton.
* turbos - these are centrifugal compressors that are mated to a expansion turbine section that captures energy in the exhaust. the centrifugal compressor is similar to design as what is described in the supercharger counterpart. its speed is driven by the speed of the turbine section which gains its speed from the energy of the exhaust. this energy would otherwise be exhausted/wasted to atmosphere. when considering the transient response of a turbo (and its resultant throttle response), from idle or a cruise, the exhaust energy is relatively low and therefore the tubo's shaft and therefore compressor is idling. when you snap the throttle open, the engine starts to move more air, produce more exhaust which the turbine section starts to capture and spin the compressor. the compressor supplies the air to the engine which can then make more power. the throttle response therefore is limited to how fast you can change the momentum of the air moving through the engine, turbine, and compressor as well as the momentum change in the turbo's turbine/compressor assembly. some common kits are hellion, HP, B&G, turbonetics.
turbos or any of the superchargers can be setup correctly for drag, road racing, dyno (whatever that means), or highway.
-chris
