Re: post 2 pics of your car
1996 mustang GT
+ MMR 4.75 Street Mod 750SE Built Block
* Ford Racing 03 Cobra Block, torque plate bored and honed
* Precision US Made 4340 Forged 4.75 Liter Crankshaft w/micro polished
journals
* Forged Steel MMR Manley I-beam Rods w/ARP rod bolts,shotpeened, magnafluxed and weight matched
* Forged Manley pistons with Chromoly pins
* Total Seal file fit rings
* Clevite Rod and Main bearings
* Ford Racing oil pump
* MMR Street/Strip 7 Qrt. Oil pan
+ Trick Flow Twisted Wedge 44 Heads
+ Trick Flow Intake Valve 1.840" and Exhaust Valve 1.450"
+ Trick Flow Valve Spring and Retainer Upgrade Kit
+ Trick Flow Camshafts,Duration 264/264, Lift .550/.550
+ Trick FLOW Hydraulic Roller Followers
+ Trick Flow Hydraulic Lash Adjusters
+ Trick Flow Timing Chain,Tension Arms and Chain Guides
+ Trick Flow Silver Valve Covers
+ Professional Products Typhoon Intake Manifold
+ Motorcraft High Flow Water pump
+ Vortech V-2 SQ Si-Trim High-Output Supercharger With Power Cooler
+ Anderson Ford Motorsport Power Pipe
+ Synapse Synchronic Diverter Valve
+ MSD Dis - 4 Ignition Box
+ MSD Coil Packs
+ Magnecor KV85 Spark Plug Wires
+ SCT BA3000 Mass Air Meter
+ 60Lb Fuel Injectors
+ Kirban Performance Adjustable Fuel Pressure Regulator
+ Accufab 75mm Throttle Body
+ Professional Products Intake Plenum
+ Steeda 1" Intake Spacer
+ Walbro 255 LPH in tank Fuel Pump
+ T-Rex in line Fuel Pump
+ Steeda Air/Oil Separator Tank
+ MMR Valve cover Breather kit
+ JBA Shorty Headers
+ BBK Catted X-Pipe
+ Borla side Exit Exhaust
+ FB Performance PRO STREET AODE (4R70W) Transmission With 2.84/1.56/1.00/0.70 Gear Ratio
+ FB Performance Racing Torque Converter
+ SCT X3 tuner
* Canton Coolant Tanks
+ UPR Billet Polish Engine Dressup
+ Snow Performance Stage 2 Boost Cooler
+ Optima Batteries D34/78 Yellow Top Dual Purpose Battery
+ MOROSO Trunk Mount Sealed Battery Box
+ Tune By Realspeed Automotive
+ SVE Front Brake Calipers
+ EBC Front Brake Disc 3GD Sport - Dimpled and slotted
+ EBC Front Brake Pad Set Redstuff - Ceramic
+ Hotchkis Rear Upper & Lower Control Arms
+ Kyb Gas-A-Just Strut & Shock Kit
+ Steeda Sport Lowering Springs
+ Steeda Alumnium Caster Camber Plates
+ BBK Tubular Polished Strut Tower Brace
+ 18X10 & 18X9 Deep Dish Godspeed Omega Wheels
+ Nitto 555ZR Tires
+ AGR Performance Rack & Pinion
+ Ford Racing Aluminum Driveshaft
+ Stifflers Driveshaft Safety Loop
+ Cobra Front Bumper Cover
+ V6 Mustang Rear Bumper Cover
+ Cervinis 3.5" Cowl Hood
+ Aerocatch Hood Pin Latch System
+ 03 Cobra Side View Mirrors
+ Saleen S281 Carbon Fiber Rear Wing
+ GTS Smoked Solar Wing
+ 1 Piece Black Halo Projector Headlights with LEDs
+ Stock Taillights
+ Sequential Tail Lights
+ MMD Billet Aluminum Fuel Door
+ Ford SVO Side Skirts
+ Mustang V6 Running Pony fender Badge
+ AEM Boost / Vacuum Gauge
+ Autometer Ultra Lite & American Muscle Gauges
+ UPR Silver Face Gauges
+ UPR Billet Climate Control Knobs
+ UPR Silver Face A/C Panel Insert
+ UPR Billet Headlight Knob
+ UPR Billet Window Switch Kit
+ UPR Stainless Steel Window Switch Plates
+ UPR Ash Tray 3 Switch Panel
+ UPR Billet Rear Defroster Button
+ UPR Billet Shifter Bezel
+ B&M Hammer Shifter With Momentary Switch Shift Knob
+ Carbon Fiber Door & Dash Trims
+ Kenwood 7" Touch Screen Navigation System With DVD Player And Surround Sound
+ Polk Audio 6 1/2 Front Speakers In Custom Kick Panels and 6X8 Rear Deck Speakers.
+ Polk Audio Duel 10" MM Subwoofer
+ Polk Audio 5 channel Amp.
+ kicker 2 Channel Amp.
+ Grand Design Mat Trunk Mirror Pony Lid Mat
