Cylinder Head Temperature (CHT) Sensor Circuit Low Input (PCM STRATEGIES 1999 AND BEYOND) Indicates a CHT sensor circuit malfunction (shorted). Grounded circuit in CHT harness
Damaged CHT sensor
Improper harness connection
Damaged PCM
CHT V PID reading greater than 4.6 volts with key ON and engine OFF or during any engine operating mode indicates a hard fault. Note: DTC P0118 may also be reported when this DTC is set, either of these DTC's will activate the MIL light.
