This is whats left:
1. SOLD
2. Rear Bumper all hardware
3. Left Side Skirt ( 2 marks on it)
4. Right Side Skirt ( perfect shape)
5. 4 Stock Springs for convertible and 4 isolators included
6. SOLD
7. SOLD
8. Truck with Spoiler, latch, key lock, struts, badges (perfect)
9. Windshield Seal
10. Trunk Seal
11. Complete Interior of truck with hardware
12. Complete Ford OEM Stock cat back with hangers and all hardware
13. SOLD
14. SOLD
15. SOLD
16. Windshield wiper cowl (under hood)
17. Right Rear window, track, motor etc assembled
18. Left Rear Window motor
19. Left Rear Window
20. SOLD
21. Airbag Control Unit (under dash)
22. SOLD
23. Throttle cable with bracket and hardware
24. 2 rear seat latch, hold downs, with hardware
25 Trunk latch with hardware
26. Inertia switch ( intrunk left side Black with Red button)
27. Complete cruise control unit with cable and all hardware
28. RR seatbelt with Hardware
29. LR seatbelt with Hardware
30. Windshield wiper motor with hardware
31. SOLD
32. Headlight Switch
33. Starter with red plastic cap/cover
34. Tensioner pulley with bolt
35. Power steering reservoir with bracket
36. 2 horns with bracket and hardware
37. Fuel Pump driver module with bracket and hardware
38. Windshield washer fluid reservoir, pump, line and hardware
39. Both rear mach 460 amps
40. SOLD
41. Main wiring harness off the ECU
42. Trunk wiring harness with light bulbs
43. Complete inside of car wiring harness with under dash everything runs down drivers side of car and across car also feeds trunk
44. Under hood fuse box and harness that crosses over radiator support
45. Battery to starter harness
46. Upper engine harness (full injectors etc)
47. Harness that goes down right pillar inside car
48. Stock air box
49. Stock MAF
50. SOLD
51. Coolant overflow tank
52. R Stock exhaust Manifold
53. L Stock exhaust Manifold
54. SOLD
55. OEM Ford Alternator, Bracket, and all hardware
56. Complete Steering Rack with inner and outer tie rods all in, bushing and hardware
57. AC compressor with lines and sensor
58. Front sway bar with bushings, mounts, and hardware
59. Sub frame connectors (stock)
60. SOLD
61. 16' Spare tire used
62. Brace (connector ) under oil pan connects each side for front of car
63. Left Strut, spindle, caliper (PBR) A-ARM-sway bar end link, ball joint, rotor, pads, stock camber plates, bushings and hardware
64. Right Strut, spindle, caliper (PBR) A-ARM-sway bar end link, ball joint, rotor, pads, stock camber plates, bushings and hardware
65. SOLD
66. Complete automatic transmission, converter, flywheel, harness shifter cable, driveshaft.
67. OEM Injectors (8)
68. OEM Fuel Rails
69. OEM Coil Packs (8)
70. PI intake (lower) OEM
71. Upper Intake OEM
72. Throttle Body OEM
73. SOLD
74. Blower Motor
75. Brake Booster Assembly
76. Gas pedal and Brake pedal Stop
77. Convertible top motor
78. L outside painted silver pillar piece
79. SOLD
80. SOLD
81. Complete Steering Column with Blinker, clock spring, Wiring and Hardware, Seal and Bearing
82. Steering Cylinder Lock, Key Assembly with key
83. SOLD
84. Fuel tank with pump and everything
85.Driver side door switch panel
86. Heater Controls in dash
87. Front seat belts
LET ME KNOW IF YOU ARE INTERESTED IN ANYTHING!!!!
1. SOLD
6. SOLD
7. SOLD
9. Windshield Seal
10. Trunk Seal
13. SOLD
14. SOLD
15. SOLD
20. SOLD
22. SOLD
31. SOLD
40. SOLD
48. Stock air box
49. Stock MAF
50. SOLD
54. SOLD
60. SOLD
65. SOLD
68. OEM Fuel Rails
73. SOLD
74. Blower Motor
79. SOLD
80. SOLD
83. SOLD
