It may be a non mass air car but you cant just change the injectors either. Speed Density is designed for 19lbs. Are you using 19lb injectors? The only other thing that I can think of off hand that will make the car load up like that is a bad map sensor. Can you get your hands on a code scanner? Maybe that can narrow the search a little.
