i figured out a few...the odd shaped one goes into the back of the steering wheel, the two farthest left that are circled in red are for sensors, ( wiper fluid), one was a hood light and another was for the brake fluid sensor
ok..i got it figured out to were it starts and stuff..and the lights, and thats all i got figured but ill look to see if i got the wires hooked up that ur looking for..and thats the only thing thats holding us back
usually i need to see wire colors but ill do my best. for the most part the wiring that comes from the driver side is everything need to run the car minus injection so youll have a plug for the headlights, alt etc. depending on what your plans are you may not need to use some of the connections. the bottom pics are turn signals horn door or key buzzer and the 3 prong is the conn. for the door switch or int. light switch if i recall correctly. if you cant figure anything out you can come down to my shop and ill give you a printout of the wiring for whatever you need.
