Before you apply them, use a spray mixture of water with a drop of dish detergent. By doing this you can move the decal around until it is lined up to where you want it.
Then squeegee from the center out, let dry for a few minutes, then remove transfer tape.
This is the easiest way to do it. But as stated above, make sure the area is clean before applying the decal.
Good luck.
