I have a strange voltage issue. I have 3 Autometer gauges, one of which being a voltmeter. My car usually runs at, or just under, 14 volts all the time. Lately the voltage has been dropping. At first it was dropping down to 12 volts, but for the last few days its been dropping down between 10.5 and 11. The voltage drop remains constant, even while accelerating. Now for the strange part. The further down the voltmeter drops the higher the other 2 gauges will read. As the voltage climbs, the other 2 gauges will read closer to their normal readings. The alternator was replaced less than a year ago and the battery is less than 6 months old. Could it be a bad cable? Ground perhaps? If it makes a difference I noticed that the wipers are moving a little slower, the windows are a little slower, and the gauge cluster isnt as bright as it used to be...
