Here are a nice pair of ported npi heads, cams with new lash adjusters and polished valves. The guides were checked along with the valve seals and are are like new. The heads had a bit over 40k on them when I removed them from my 97 GT about a year ago. If you are a npi guy you prob think that the npi heads are terrible however most the horsepower difference between a pi and npi set up is in the cams and intake. The head swap gain is almost purely from the compression bump from a smaller combustion area. These heads will out flow stock pi heads easily and give a mildly set of ported pi's a good run for their money! Stock flow numbers of pi vs npi heads are close, in fact above .45 npi OUT FLOWS pi heads stock!!! check it out!
shipping is going to be nasty on these guys, I checked the weight on one head/cam/ assembly and it weights ~45lbs and with a box appox 24/12/10 inchs shipping will be about 50 bucks or so for even around NY (california was ~$100)
I would like to get $400 for the set. Thanks for looking!
