How are you Joe? I had you guys do a transmission swap on my grey 04 gt. Don't know if you remember. Was very happy with the work, and now I need some more work done.
I want to lower the front of my car some more so I would like to remove the front isolaters. And I need some maximum cc plates installed to get the car aligned correctly. I would be bringing the cc plates along. My car also just recently lit up the check engine light. I would like you guys to check it out. Also, do you guys do wheel alignments? I recently threw on new rims and tires and would like the car to drive perfect.
So 4 things.
Remove front isolaters
Install MM cc plates ( bringing my own)
Check engine light
Wheel Alignment ( If possible)
Can you give me an estimate for the work I need? Thanks!
So 4 things.
Check engine light
