I'm running kenny brown adjustable lower control arms and i DON'T recommend them. They will be swapped out ASAP. I'm running 93 cobra stock uppers.
What are you looking to do? Drag racing, street handling, road racing? If you want better handling around corners, avoid using aftermarket uppers, the stiffer bushings and construction will cause too much bind in the stock 4-link geometry.
-Chris
