Hopefully someone can chime in with an answer to my question. Here's my situation; The Vortech pump that comes in the V3 SC kit ("00 GT) fuel pump duty cycle (fpdc) was pretty much at it's limit on the dyno @ 6000rpm. I made my own air to water intercooler and reduced the pulley size to 3.33. Back on the dyno my latest mod added 26rwhp and 30rwtq, now I have 390rwhp 380rwtq. Now the Vortech pump was at 100% fpdc at 5200rpm. I installed lethal performance's 340lph fuel pump. After another dyno pull I go 100% fpdc at 5900rpm. Not much gain there with the new pump.
So I'm looking to do the wire upgrade as my battery is in the trunk now anyways.
My question, is the fuel pump in a '00 mustang GT modulated by variable voltage or pulses? Does the typical wire upgrade that uses a 30-40 amp relay, splice the green/yellow wire to energize the relay, run 10awg wire to common contact on relay (pin 30 I believe) and increase wire size to fuel hat, still allow this variable voltage/pulse to work correctly? Or does my year ('00) fuel pump get constant 13.5 volts all the time?
I know I explained a lot in details but I want to be sure this question is answered properly before I do the upgrade.
P.S. In researching this dilemma I found that the 255lph pump should handle 390rwhp. I found a good approximation of fuel requirement is HP X .47 for forced induction engines. 390 X .47 = 211.5lph. Why is a 340lph pump falling short? Did anyone find similar results with such a setup?
Thanks in advance for anyone reading/understanding my question and providing an answer!!!
