I have a 1995 v6 mustang, and the driver side seat is a power seat. only problem is, about a month ago it stopped working. hopefully its just a fuse, does anyone have a fuse diagram with the seat located on it? It would be so much help. Thank You
there should have been Do u have a test light u can pick one up for 5 bucks at an auto parts store, just run it over all the fuses should take u all of 30 seconds to see if any are blown
i blew that fuse in my 95 v6, it's the same fuse that goes to the cigarette lighter ports and thats how i blew mine, either the penny that was in on of the ports or the fact that i was using both at the same time. unfortunately i discovered that not only could i not use the ports but the power chair was done for too. either way i changed all the fuses in the drivers side fuse box turned the car on and still nothing. so when i had the car in the shop for brake work i had them check it out and i explained the situation to them and said that i hadn't checked the fuse box under the hood. today when i got it back everything worked and all they charged me was $12. sorry my car didn't come with an owners manual but if you have one look in there for the fusebox under the hood
i dont have an owners manual either, but ill check under the hoods fuse box as well. I guess that kinda makes sense with the cigarette lighters cuz neither lighter has ever worked in my car, and i guess it was just a matter of time until the seat went too. lol. but thank you. thank you everyone
