Well i changed the coil spring today. So i figured working on the car might aswell put the rest of the refurbished injectors in it. So long story short damn thing will not idle worth shit. Seems to be running rich. I have on o2 sensor not hooked up from previous owner. Not sure if that is causing this issue? Ran fine at idle before i put the rest of the injectors in it. Now it acts like a vacuum leak but as far as i can see all the hoses are hooked up like before. The car has no cats just headers to h-pipe to thrushers. Don't ask that is the way i got it. So what could be causing this issue? Has me stumped. Ok would the hose running to the pcv valve became unhooked from the intake when i installed that last injectors tonight be causing this issue i am having?
