Hey guys,
I spoke with Joe at Mustang Magic and as most of you know I am adding the Vortech air-to-water intercooler on to my car this winter and Long tubes and an H Pipe (bigger MAF as well)... Joe said that he has seen HP numbers between 460-495 to the wheels with a 12 pound pulley...with the combo that I have depending on whether my car is a low performer or high from Ford.
Needless to say I am a bit worried about the bottom end of the engine, I asked a few questions back regarding forged internals and such... I decided that it may be cheaper and less of a pain to just purchase a Short block or a Stroker Short block. Here is what I was looking at... let me know any opinions you guys have or any advice that you could offer...
This probably will not get done until next winter but I may purchase ahead of time such as next month to be able to have it in case anything happens... The other question was should I just stick with my factory heads and have a valve job done on them or what?? This is new territory to me so I am hoping somebody can spread some light on it..! Also should I add any options that are listed below...
MMR 2005-2010 Mustang Annihilator 900 4.6 Short block
*Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
*New 4340 Forged 3.543 stroke Cobra Crankshaft w/micro polished journals at no extra charge-This is the strongest crank available.
*New 4340 5.933 Manley H-beam Rods w/ARP Rod bolts ( These US made rods are shotpeened, magnafluxed and weight matched to bring you the finest H-beam rod available for your 4.6
*New CUSTOM MMR Lightweight Manley pistons 3.552 Bore size, 2618 alloy, tool steel pins, pressure balance groove, full banded skirt for increased stability, valve reliefs for 3V cylinder head.
*Speed Pro file fit rings 1.5mm Top, 1.5mm Second, 3mm Oil ring(precision file fit to your application, nitrous, blower, turbo or N/A)
*Speed Pro/Federal Mogul Rod and Main bearings
*Complete Pro Assembly, blueprinted and digitally Balanced for the smoothest, highest revving shortblock available for your 05'. Includes MMR Billet adapter for 2005-2010 3V Motor Mount This engine will handle up to 900HP!
MMR Proudly uses the following manufacturers in ALL engines!
ENGINE OPTIONS
New Aluminum block $999.99
MMR 2005-2010 3v Street/race oil Pump (highly recommended) $199.99 (save $30)
MMR 2005-2010 7Qrt Oil pan, Red, Black or Silver $229.99 (save $20)
MMR 2005-2010 oil pan windage Tray +15HP! $129.99 (save $10)
Upgrade Rod Bolts to ARP 2000 (nicest bolts available) $99.99
ARP Main Stud Kit (recommended for 600+HP) $169.99
Plug and dowel Kit (required when switching from aluminum Block) $69.99
MMR/Felpro 05-10 Head Gaskets (used in our 1500 HP racecar) $169.99
ENGINE OPTIONS
