U could try without them first and if your valves are not making noise your good to go, I would try to to start the engine without them first and make sure it reaches operating temperature, U may not need the shims, if by any chance your getting a valve tap, then your going to have to re-install them, it's better to have a tap, than to make your valves to tight and you end up wiping out your Cam lobs
