have a msd 6btm just wondering
still have my stock rev limit if i put a pill in the msd will it override my stock rev limit my motor can go more than 6800
theres nothin in the msd right now
thanks
The 6462 box has a chip limiter built in but no it will not over ride the stock computer fuel cutoff. If your car is boosted have the factory limiter shut off, last thing you want is the computer pulling fuel under full boost.
You do that in the tune. You will need to have the car tuned to play with anything the the ECU. I looked at my BTM (Vortec model) and I did not see a spot for a pill. Just the wire harness and the vacuum nipple but I can't see the bottom.
He's got the 6btm which is the 6Al with the btm built into it. So it will have the soft touch rev limiter. What you probably have is the plain btm which is what comes with the vortech kits.
