After 3 weeks or so and very little time to work on the car I finally got the BBK long tubes, O/R X pipe and cat back done last night. Some of you know that the BBK long tubes don't fit a car with an AOD, well these do now. They hit everything. A/C lines, K frame, trans pan, trans linkage, starter and the air tube didn't fit after they were installed. Both of the O2 sensors bungs had to be relocated as well. A little cutting, bending, welding and drinking got them in there with little room to spare. I had to cut the origional 4 into 1 collector off the driver side and use a less bulky 4 into 1 weld on collector from hooker. Only issue now is because the driver side had to go so low to miss the shift linkage, it is a little close the the ground. Not really bad but it could be better. Only thing left to do is take it all back off again, clean it up and coat the welds. I will get a vid tonight if it's not raining. It wasn't that bad to do but kind of pointless when none of it will be able to be used with the next motor come next spring.
