I bought an aftermarket package tray and the fitment of it with the rest of the interior was horrible. i decided to make my own interior trim pieces and wrapped them with vinyl instead of the plastic like the original ones. i redid the "hockey sticks" and made a filler piece that goes between the rear seat and the quarter panel. they came out pretty good but i put foam on them to add padding and it doesnt really match the rest of the interior pieces so i think i will take them apart and remove the foam.
before
trimming and marking off the fiberboard to make the new ones
drivers side done. even though it looks like its not straight at the top it definitely is, that is the padding that makes it look like the top is not cut straight.
passenger side done
i also ordered and installed a cover that goes between the radiator and the front grill. originally its just open and you can see all the wiring the front of the radiator/condenser. along the front of the piece is a rubber trim piece to prevent any cuts from running your hand across it. i looked high and low for a red rubber piece because it is almost perfectly inline with the red stripe on the fender. if anyone can find one for me i would be so great full.
before
passenger side done
