Google is a friend!
" the fuel pump relay is part of ccrm(constant control relay module) which houses other relays as well. it is located on the passenger side behind the splash guard. you would have to replace the entire ccrm unit. if your fuel pump keeps going out i would also check your fuel pressure sensor and your fpdm(fuel pump driver module) which is near the inertia switch(the thing with the red button) in your trunk. and also what pump are you using as a replacement?"
