They are easy enough to replace. You have to pop out the plastic piece which houses the lock/window switches. Underneath you will find a couple of screws you have to remove. On the front of the panel there is a clip that has to be removed. The panel will then lift off. The speaker removal will be self explanatory. Stock size is 6X8.
