e85 requires about a 30% increase in fuel supply across the board so you need to change the pump and the carb at minimum, and if youre running small lines youll need to upgrade those as well. rejetting the carb will cause problems that you are not aware of, there is a very good reason they make carbs just for e85. if you are prepared to ruin your engine, carb and fuel system then by all means continue. e85 is not cheaper than reg. gas but it is more consistent and can produce more power if you know what youre doing, the biggest problem with e85 up here is it is not e85, its a varying blend that can be e65, e75, e85, etc. it changes by season and by vendor so it makes it hard to tune. also you need to understand that e85 does not have the same stoich so tuning for 14.7 will not work. do research before you destroy your car.
