I have a 85 GT w power windows and need to replace the door. I found a 90 GT w the same color door. can I use the door panel from the 85 on the 90 door?
The doors are the same but the moldings on the outside are different and you might have to drill some holes to mount the '85 door panel on the '90 door.
The only other thing that might be an issue is the wiring. It may not match up to the 90. You might have to strip everything out of both doors and switch it around.
