It is 2 different power bands and when people say Hellion, Hellion does not make turbos they make kits and in many cases there kits are restrictive with small pipe work and to many bends, therfore tuning them for driveabilty at times is tricky. I cant see spending the money on a Turbo on a stock block and never running the Turbo were it likes to run. Example with twins, I have a customers car that has twin 61mm and he runs them at 7psi per turbo, imo that is useless you can run one 61 at 20psi all day. I like Precision turbos much better.
Blowers are fun all around because there is no lag and power is instant for a street driven car with a stock engine. Do not get me wrong, Turbos will make more power but with that also comes the price tag. Turbo's like to eat parts and break things as well so you need to think long term what your plan for the car is before you spend a dime. We carry all blowers and turbos so let me know if we can help. We also offer free pick up and delivery and Kevin is a outstanding tuner blower or turbo.
I understand that Hellion doesnt manufacture the head units but design kits around the TC its self. This isnt my first turbo car. But this will prob be much more efficiant than my JY twins on my 86. Alot has changed since then as that was over 8 years ago when incon was still around. as far as pipe sizing I would think that been taken into account with the efficiancy of the head unit casing, perpeller, bearings, cooling, ect. All kits are just that, kits; even supercharger kits are built for the general masses and may have pluses or negatives in one area or another.
I know I asked which direction I should go, but this was not because I did not know what a turbo or a twin screw was... but that this is my first on a modualar engine. I have run pretty much everything out there other than this new compound boost thing. the 88gt went from S-trim to T-trim, 86 gt went from T-trim 331 to twin t3/4's, 95 cobra 5.0 dss block with a KB 1.7
This 4.6 is a new animal to me as the low end torque lacks compaired to traditional pushrod engines but with a positive on the upper end of the rpm curve where turbo's thrive. reguardless looking at a
Your comment about turbo's "eat parts and break things" had me confused as this is the norm with any modification beyond manufacturers or designers specifications. Any supercharger/Turbo/Nitros ect with have the same issues when not configurd or tuned correctly within the safe AFR/HP window or the parts its supporting. when you combine racing with the need to go faster any technology used will "eat parts" as you put it.
I do appreciate your assistance...but i think i will be going the turbo route.
Fun part is I dont need to do tons of welding and play with the tables in the tweecer for 4 months.
like years ago.
JD
