I spent that last couple days building and adjusting the throttle cable set up. I started with a universal Lokar cable and modified it to fit.
the first issue being the 67 mustang never came with a throttle cable but with a throttle linkage , so I had a 69 gas pedal in the parts box that would work a bit better. I had to cut off the factory end and make my own to work with the Lokar cable tho.
stock
mine
cut the cable/ housing to fit on my bracket I made.
one thing I liked about the lokar cable is that it had tons of adjustment on both ends of the cable and the housing. So this allowed me to not only adjust where the throttle started/ ended but also the pedal height. Once this was done and I had the pedal where I wanted it I decided it was too soft, so I needed to add a return spring, after trying a couple different lengths and resistances I found one I was happy with. So not only are the pedals more even( before the gas pedal was way down and the clutch stuck out.) but the amount of pressure needed is exactly what I want. This should make the car much more enjoyable to drive now.
