Not to sure how well you know the area....If you we can exchange PMs of each others numbers and Ill be able to help you get to the Northern NYM lot but it really is simple to get too!
You would most likely want to get yourself onto the highway (I87) and go south from Lake George to ext 19...Depending on witch exit you got onto from LG then its only 2 or 3 exits...You go right off ext 19, straight over the bridge and through the first light, at this point I would get into the left lane but you will go through another two lights both pretty close to each other and then you come up on a bigger intersection where you would want to take a left and right there is the Norther NYM lot on the right...You wouldn't be able to miss us!
We plane to meet up at 7pm and take the decent little ride into Lake George where Im going to have a planned spot for all of us to park so we can then hang out for a bit in till ten when the actual car show cruise end then we will start the NYM cruise..Right into the main strip where we can take the spot light
What does everyone think!?!?!
