Borla Stinger S-Type Cat Back, X Pipe, Test Pipes No Cats
Straight Pipes all welded into one piece from heads to tips (well to half the cat back because the borla is 2 pieces clamped on each side)
LOUD & MEAN!!! $700
2001 Mustang GT Part Out
*Desperately need the money, the more you get the lower the price! I'm super reasonable and grateful but don't try to low ball me I need the money don't be a d***.
Parts are MINT only 30k miles on the car, very clean & no rust or wear!
Silver Exterior - Dark Charcoal Leather Interior
Shell $best offer
Dark Charcoal Leather Front & Rear Seats $500 SOLD
Seat Tracks $150 SOLD
Rear End $400
Driveshaft $75
Stage 3 Clutch $350
Tein Lowering Springs with shocks/struts $300
Calipers $30 each
Caliper Bracket $10 each
Barely used brake pads $30 all 4 sets
Rotors $25 each
Rack and Pinion $60
Spindles $75 each
Rear Sway Bar $150
Control Arms $
Rear Lift Bars $150
BBK Cold Air Intake with filter $150
Straight Pipe Exhaust - Borla Stinger S-Type Catback, X Pipe, No Cats! Welded in 1 piece $700
Rear GT Bumper $200 SOLD
Passenger Fender Silver $60 SOLD
Trunk Lid w/ Spoiler Delete Silver $150
Radiator Support $250 (brand new in original packaging w/ receipt)
Bumper Support $60 (brand new in original packaging w/ receipt)
V8 Engine - bring a mechanic $800 obo
2001 GT ECU $75
Transmission TREMEC TR-3650 5-speed Manual $500
Short Throw Shifter - TR-3650 $125
Full Dash Board Black $100 SOLD
Center Console (btwn seats) $70 SOLD
Door Panels $50 each SOLD
Door Panel Cup & Switches Insert $40 each/ $60 both SOLD
Door Panel Handle Cups Insert $10 each/ $15 both SOLD
Both Door Panels with inserts $175 SOLD
Door Handles $15 each
Headlight Switch Knob $15 SOLD
Vents $10 each SOLD
Trunk Carpet $30 SOLD
Door Sill Trim $10 each SOLD
Mirror Covers (Interior) $5 each SOLD
Glove Box $20 SOLD
Cluster $25
Steering Wheel with Airbag $140 SOLD
Seat Belts $100 each OBO
Double Din Dash Radio Bezel w/ vents & buttons (fog lights, traction control, defrost) $75 SOLD
Stock Radio $35 SOLD
Stock Speakers
-Tweeters $5 pair
-Door Speakers $15 pair
-Rear Speakers $15 pair
Rear Speaker Deck $50
Rearview Mirror $20
Mirrors black $25 each (passenger side SOLD)
Climate Control Module $20
Blower Motor $50
E-Brake Lever $20
E-Brake Cable a Front $20 SOLD
E-Brake Cable Rear $25 each
ABS Control Module $75 SOLD
ABS Wheel Speed Sensor $35 each SOLD
Tail lights $50 pair
Black Rims $175 all 4
Brake Booster with Master Cylinder $150
Radiator $50
Radiator Overflow Tank $50
Radiator Fan $50
Radiator Hoses Set $100
Power Steering Reservoir $50
Windshield Washer Fluid Reservoir $50
Horn $25
windshield Wiper Cowl $40 SOLD
Windshield $100
Heated Rear Window $100
Quarter Windows $25 each
Window Regulator $75 each
Windshield Wiper Arms $40
Windshield Wiper Motor & arm linkage $30
Fuel Tank with Shield $175
Fuel Pump $100
Fuel Tank Filler Neck $75
Fuel Filter $10
Fuel Door Silver $30
2001 GT WIRING HARNESSES:
ECU Wiring Harness $175
Dashboard Wiring Harness w/ Fuse Box $150
Body Chassis Wiring Harness $175
Starter Battery Wiring Harness $50 SOLD
ECM/PCM Wiring Harness $100
Injectors Wiring Harness $200
Engine Wiring Harness $175
Not sure what all the harnesses are called... pictures upon request
Any other parts needed just ask!
Text me 5one63four39one75
Thanks!
LOUD & MEAN!!! $700
Shell $best offer
Rear End $400
Driveshaft $75
Stage 3 Clutch $350
Calipers $30 each
Rotors $25 each
Rack and Pinion $60
Spindles $75 each
Rear Sway Bar $150
Control Arms $
Rear Lift Bars $150
2001 GT ECU $75
Vents $10 each SOLD
Glove Box $20 SOLD
Cluster $25
Stock Speakers
-Tweeters $5 pair
Rearview Mirror $20
Blower Motor $50
E-Brake Lever $20
Radiator $50
Radiator Fan $50
Horn $25
Windshield $100
Fuel Pump $100
Fuel Filter $10
Thanks!
