My clock has been flickering for a while now and yesterday it just shut off but the strange thing is when i turn on my headlights it turns back on. has anyone ever run into this sort of problem? is it the clock itself, headlight switch or maybe somewhere in the wiring?
Do not know your car, but sometimes there are two settings (maybe even two separate circuits/bulbs), one for when the car is running and a second when the lights are turned on.
Sounds to me like the clock itself is crapped out.
it going on when the headlights are turned on tells me that it is working, but the illumination on ignition is screwed up, but the dimmer circuit is working fine.
Now I'm completely confused, the clock started working again with the headlights on or off,the time hasn't changed and its not flickering either. I guess ill leave it alone till it stops working again
