Mustang GT / V6
Roush 20" x 9.5" Wheel (Hyper Black) / Cooper Zeon RS3 Tire (275/35 ZR20) Combo
If you want your Mustang to look it's best, you need aftermarket rims. This 2005-2013 Mustang 20" x 9.5" Hyper Black cast aluminum wheel from ROUSH features their classic five-spoke design and the ROUSH logo embossed on the surface. Install four of these on your Mustang and you'll be turning heads.
Cooper and ROUSH developed the Zeon RS3 Tire specifically for ROUSH's most powerful high performance Mustangs: the Stage 3 and the P-51B. The Zeon RS3 tire has a 'W' speed rating. If you're familiar with tire rating codes, you know that a tire with a rating of 'W' is deemed safe to drive up to 168 mph. Its optimized spiral-wound nylon restrictor provides outstanding high speed stability and its high density steel cord belts offer superior tread band stiffness. Made with silica technology, it has low rolling resistance, superior heat dissipation, improved tread life, and excellent adhesion, even on wet roads. Its asymmetric, non-directional tread provides top-notch cornering stability and great water scavenging. This feature also allows you to rotate the tires, as all four are identical.
Each wheel / tire includes TPMS Sensors and comes with a
12 mo. / 12,000 mi. warranty.
Featured Part:
This part is a featured item in "[[How to Upgrade Your 2005-2009 ROUSH Mustang]opup=
