DG Custom Fastback Side Scoops (TruWeave HydroCarbon / Painted)
Looking for something different from the normal painted side scoop? Try DG Custom Auto's Painted Side Scoop with the mix of TruWeave HydroCarbon. This scoop comes to you with high quality paint mixed with the clean look of DG Custom's HydroCarbon finish. You can select the inner or outer area to be painted!
Please select your desired paint color from the drop-down menu above.
Make sure you order the correct color to save yourself from a potential restocking fee.
MADE IN THE USA!
Inspired by the 1966 Fastback Mustang, DG Custom's new side scoop will add old school flare to your 2010-2013 Mustang. Molded from ABS plastic and painted with insurance-quality color matching, these Mustang side scoops are sure to look great for years to come.
DG Custom's 2010-2013 Mustang side scoops install with included high-bond doubled sided tape for a secure, long-lasting fit.
Look here to make sure you order the correct paint code: [[Mustang Paint Codes - Click Here]opup=http://www.stage3motorsports.com/ca...ked_questions__faq_.faq__mustang_paint_codes/]
Important Notes:
- This product ships pre-painted. Please select your desired paint color from the drop-down menu.
- 10-15 Working Day Turnaround on Products Not in Stock: (this product is has a 2 stage paint process and requires more time to complete).
