On my second mustang.... but new here.
Timspony Capital District Coordinator / Super Moderator NYM Staff Jan 28, 2011 #2 Jan 28, 2011 #2 Welcome to ... nice looking Fox!
D DoggyOnDown New Member Jan 28, 2011 #3 Jan 28, 2011 #3 thanks i've had it 2 weeks and its been stuck under a cover and 2 ft of snow. can wait to hit the street.
dsblk93gt 5.0 Moderator Jan 29, 2011 #11 Jan 29, 2011 #11 Welcome!!! My 1st Mustang was a 89 LX hatch
D DoggyOnDown New Member Feb 1, 2011 #17 Feb 1, 2011 #17 thanks for the warm welcome.... he is some info on the car Modifications History: Chassis & Suspension: Welded subframe connectors Steeda UD rear upper control arms Steeda Rear Disc Brake conversion Steeda Brake Proportioning Block Larger piston front brake calipers Energy Suspension poly Trans x-member bushings Energy Suspension poly Trans mount Steeda lower G-load brace Custom rear lower control arms Reinforced and welded torque boxes Steel Braided brake lines, front and rear Maximum Motorsport Panhard Bar New Ford Motorsport HD front control arms Poly front sway bar endlink bushings New power steering pump New power steering rack and poly steering rack bushings New front bearings and rotors Brothers Performance bump steer kit tie rod ends ‘95 Mustang master cylinder Energy Suspension greasable poly front swaybar center bushings H&R Springs New spring isolator bushings Maximum Motorsport strut tower brace Maximum Motorsport Caster/Camber platesDrivetrain: BBK aluminum clutch quadrant Ford Motorsport aluminum driveshaft Steeda leather shift knob BBK driveshaft safety loop Rear end completely rebuilt by Stampers Hi Performance in Ricthmond Virginia: New Ford Tractionlok carrier assembly, Moser 28-spline axles, inner & outer pinion bearings and seals, upper axle end bushings, Motorsport 3.27:1 gearsNew speedometer cable, sensor, and gear New HD World Class T5 transmission (2.95:1 ratio Vt gear, 0.63:1 ratio geai; high capacity 3’ gear cluster mileage at installation approximately 116,000 miles.) New Motorsport 3.55:1 gears installed Mobile One synthetic trans fluid New Clutch cable Steeda firewall clutch adjuster New Pro 5.0 Power Tower shifter with adjustable stops and Steeda bushing with stock size shifter handle New Ford Motorsport King Cobra clutch, pressure plate, throwout bearing, shift fork, & pivot ball, & new SOoz. fly wheel Rear differential clutch pack replaced Mobile one synthetic rear gear oil Engine: BBK 70mm throttle body & EGR spacer BBK underdrive pulleys New temperature sending unit Edelbrock high volume water pump 180 degree thermostat New battery cables New coolant overflow reservoir Flex Fan New Ford 302ci short block (6009 B50) with Steeda # 18 cam shaft. (220 intake / 226 exhaust duration @ .050 lift) Camlobe .3001. Liftwith 1.7 rocker anus- .510 Double roller multi index timing chainAPP head bolts Edelbrock Performer 5.0 aluminum heads 1.90 hit /1.60 exh valve size Edelbrock Performer 5.0 intake Accel fuel pressure gauge Kirban fuel prcssure regulator New Ford oil pump (reg. volume) w/ N]) oil pump shaft Motorsport 302 windage tray PPI ND motor mounts 24pph fuel injectors New A.I.R. sensor New Radiator hoses ‘93 Cobra computer & 70mm Mass Air Accel Billetech Race distributor Crane Cams ignition coil Mac True Fit long tube hedders, (1 &5/8th primary) Mac Hi Row catalytic converter H-pipe Motorsport Hi torque starter 2.5 inch Walker Dynomax cat-back exhaust system New exhaust hangars Fluidamper harmonic balancer Crane 111-6 capacitive discharge multiple spark ignition system Fluidyne Hi flow 2 core aluminum radiator AFM (Anderson Ford Motorsport) Power Pipe cold air induction system with K&N Filter New idle air bypass installed New throttle position sensor installed 190 lph fhel pump New battery New 90amp alternator New Bosch oxygen sensors Last edited: Feb 1, 2011
PrjctLxEnvy Rockland County Coordinator Feb 1, 2011 #18 Feb 1, 2011 #18 oh my, nice list welcome to the site, seems like that little LX should handle pretty well
