Just finished a fresh rebuild on the 302, pulled the car out of the driveway to do some work. About an hour later I pulled the car back in the garage and turned it off. After I turned it off, smoke started coming up around the engine and I looked under the car to notice the smoke was coming from the front of the transmission. Also it was leaking (Slow drip) a brown/burnt fluid which had a real strong odor. I attached a picture to show where it was leaking from. Right where the "J" shaped lip is, is where it was dripping from. What could this be?
