I have a Lentech Valve body. It came out of my Lentech Strip Terminator Lockup AOD. I burnt out Overdrive and 3rd gear started to go. When I had the whole transmisson replace with a Freddy brown unit. They use there own Valve body. I asked them if this Lentech unit was still good. They told me it was the only part in the trans that was still good. It shifted fine even before I had the transmisson replaced.
Part# 7A100-AOD-STRB New they go for $845.00. I'm asking $500 OBO
IT'S A MANUAL SHIFT VALVE BODY AND HAS TRANSBRAKE ALSO.
Operation:
Featuring the industry's fastest AOD transbrake, the Lentech Strip Terminator showcases Lentech's reverse/third technology which enormously increases torque capacity. Available in full manual shift only, it is very quick and responsive. Because of its fixed line pressure, with this valve body the transmission is no longer succeptible to failure from incorrect TV cable adjustment ( TV cable NOT to be used with full manual models ). This valve body is a MUST for AOD's needing to withstand 600+ hp.
Features:
.Forward 1-2-3/4 shift pattern with electric O/D delete
.Patented Lentech Rev/3rd operation greatly increases torque capacity by applying two clutches in third gear eliminating input shaft breakage
.Lightning fast transbrake response
.Increases flow and volume to lube and cooler circuits
.Operates at fixed line pressure
.Includes pre-calibrated separator plate
Suggested Accessory:
Install and Wiring Kit Part# 7G276-TBWK-WC
I also have a RCI SFI Transmission Blanket. Also When I changed over to the F.B trans. I went with an SFI bellhousing. So I have no need for this. Looking for $50 for this.
Operation:
Features:
