I just installed an ebach spring kit and new hotchkins rear control arms, i took off the quad shocks and the rear end feels like it sways anybody have any advice? thanks
did you put the rear sway bar on? (i cant remember the correct name for it) the bar that links both lower control arms. i left mine off for a test run and it felt like the rear was on ice.
Did you get the eibach drag springs? If so you might have put the springs in wrong. One is a higher spring rate and tension which belongs on the passenger side. If you reversed them the car is gonna launch whacky.
