Hi everyone After figuring out my computer went bad and cross threading a spark plug. I pulled the head off had the hole fixed and put the motor back together. I had set the valves having Compression when turning the motor over by hand. Set everything and ran the car. I changed the oil and ran the car again. I had a friend come over and we adjusted the other side of motor valves Because they were making noise.
So we went back to the otherside to readjust them (they made a little Bit of noise). But as we were truning the motor over we notice that we couldn't get any compression. We had it in the first hole But nothing in the 2nd or 3rd holes. We went back to the first hole and No compression.
So I broke out a compression tester. Drivers side had 150 as test. Went to passenger side of the motor and Had 0 0 0 on 1,2,3. I didn't do a leak down test. Just crank the motor over with the starter.
What do you guys think Bad gasket? I can't see screwing up all the rings on just 1 side of a motor. When I pulled the head back off the Whole gasket was wet. Even places that it should not have been. When I did the torque specs I use the factory specs. Any problem with that Or do the MLS gasket and arp studs require more torque?
