I am about to install AFR 165 and holley sytemax intake on my brother 92 conv. currently the motor has a b-cam and 1.7 rockers with comp cam springs, shorty headers, off road h-pipe, 65mm throttle body, 75mm maf C&L and the chinese edelbrock knock off intake. The AFR's I will be using 1.6 rockers, so I was thinking with only .480 lift it may not utilize the heads as well as can with other cams. I was thinking of either the Lunati 51014 cam, Wolverine 1087 knock off by speed pro, or an f-cam.
Of coarse I am going to check Piston to valve clearance, but it makes life easier if someone says they have used that combo with stock lower end and it did or did not clear for them. I would like to be able to complete the work the day/weekend I start on it and not have to look for another cam while it is apart.
Also, any input on the combo positive or negative is appreciated.
Thanks
Thanks
