Short block: Over $6k to build new. Asking $4,250
Ford SVO R302 block
4 bolt mains on the center 3 caps
Siamese bore
Eagle 4340 Forged Crank 3.4" stroke
Eagle 4340 H-Beam Rods with ARP 2000 bolts 5.315"
Venolia custom nitrous pistons with gas ports and pin buttons 4.105" bore
Total seal nitous ring package
360 ci total / Internal Balanced
ARP BBC main studs
Windage Tray
ARP 1/2" Head Studs
*New rings, fresh hone and deck, new bearings*
*Pistons fit Brodix Track 1 and similar inline valve heads*
Heads, intake and rocker package: $3,000
Brodix T1F 225 CNC heads.
2.10in / 1.60ex valves
ISKY RAD series tool steel valve springs good to over .750" lift
Flow 331cfm @ .7" intake
Dual exhaust bolt pattern (standard and high port diagonal pattern)
56cc chambers
Probe Aluminum Shaft Rockers
Edelbrock Super Victor 8.2 intake. Port matched to heads with bungs installed for nitrous fogger.
Induction Solutions Big Shot Nitrous Plate System: $500
NOS Big Shot plate flowed and blueprinted by Steve Johnson. (2) Nitrous solenoids and (1) Fuel solenoid ported and flowed with teflon plungers. Has solenoid mount, jets for 150hp through 350hp and the blueprint sheet for easy tuning. Tons of $$$ invested!!
Ford Motorsport aluminum valve covers with vaccum regulator welded in. $100
Camshaft Innovation Solid Roller N2O cam: $275
113.7* lobe separation
Adv. Duration 318*in / 347* ex.
Duration @.05" 262*in/ 280* ex.
.730"in / .708"ex lift with 1.6 ratio rockers
Accufab Custom 8.2" deck headers: $550
High port staggered bolt pattern
1 piece construction with thick flanges
2" primaries / 3.5" collector
O2 sensor bungs installed
Has a couple dings on the bottom from some wheelies
but nothing performance impeding.
Moroso Oil Pan and pick-up: $175
Real solid construction, painted black and looks killer!!
JW "The Wheel" Flexplate: $75
Still in SFI Cert.
157 tooth
Zero Balance
Chrome 1 wire alternator: $100
Summit brand, 3G case
100 amp with 6 rib serp. pulley
Edelbrock 1" carb spacer: $10
Black phenolic, fits 4150 carbs.
Billet Throttle Cable Bracket: $45
Summit Brand, clear anodized, works great. Just like the Holley, Jegs bracket. Fits 4150 carbs.
Call Doug @ 450-1827
Email djvanstrom@eha.us.com
Ford SVO R302 block
Siamese bore
ARP BBC main studs
Windage Tray
ARP 1/2" Head Studs
56cc chambers
Still in SFI Cert.
157 tooth
Zero Balance
