Oil pressure.
I've had this problem for a while, not sure if its the oil pressure sending unit or something else i noticed that after the cars been driven for a bit and gets warmed up the oil pressure when its at low rpms is extemely low but thats according the gauge, which i really don't trust any of the gauges in the car. anyone have any ideas on what it could be. maybe the after market valve covers from pepboys arn't maintaining pressure, they are held on by t handles which loosen up to freaken easily. also has a second breather hole on opposite valve cover which i have a breather in. or maybe the sending unit is going bad.
Actually instead of making multiple post on issues im just gonna list them all here.
Steering issue
The next problem that has risen is there happens to be a ton of play and response in the steering it's reacting heavily to every little bump in the road not sure why.
Idle issue on start up
After its been driven for a bit just like the oil pressure issue, i noticed that if i turn it off then start it back up, the idle for a couple of seconds sounds like its gonna bog out, then it goes away.
Anyone have any ideas on what's causing these issues, please help be greatly appreciated.
Steering issue
