OK, got the old one out here are the pics. How the heck do i wire up the one i bought from cledusdtrucker?? It has a small spade terminal, and two stud terminals. How do i make this "mini" starter work on my one wire connection car???
Your going to have to run a 12 ga wire from the right post on the solenoid on the fender to the spade connection on the starter and your heavy gauge cable will go from the left post on the solenoid (same post that battery power comes into the solenoid on) to the post nearest the engine block on the starter. So basically you will now be using the starter solenoid on the fender as a relay for the solenoid on the starter. get it?
