okay so i took it to my mechanic and he tested the TPS, AIC, ran the codes ...everything came back good...he had one code that was for a "flapper" on the stock airbox control i guess but said that since i have an aftermarket its not there and shouldnt affect it...he tuned the idle up a little which helps but its not a permanent fix he said...here is my list of mods and where should i go next? do i need a custom chip?
BBK headers, h-pipe to borla dumps (b4 rear axle)
BBK 70mm Throttle Body
BBK 70mm MAF
BBK CAI (fendermount)
3:73 gears
F303 cam
GT40 Upper and lower intake manifold
BBK FP regulator (at 38lbs at idle)
19lb injectors
200a alternator
thanks
BBK 70mm MAF
3:73 gears
F303 cam
19lb injectors
200a alternator
thanks
