Well I am in desperate need of cash (approximately 3000 bucks for a  largely stupid mistake i made, but dont want to talk about), and I am  attempting to avoid having to part out or sell my car.  So my priorities  and plans have changed for some of the stuff.  The rest I just want  gone.  I would appreciate any help you guys can offer.
Shortblock: Asking $1500 obo
Teksid Block with a 9.1:1 compression
Ross Pistons with a 16cc dish, Ceramic and hard skirt coated
Manley Rods
Cobra Crank
ARP Everything
Will include the already modified motor mount adapters to bolt it into the car.
The engine had about 7000 miles on it when I had an oil pump failure. I replaced the pump and ran the engine for another year with no issues. There was a slight tap or knock when it was cold but it went away when it warmed up. I never did find out what it was. The block uses all standard size bearings so you can bore and machine it without a problem. I would probably just freshen up the bearings as a just in case thing and that was my plan this winter but priorities have changed. The motor ran a best of 10.7 in the quarter mine on 93 octane with a rich tune. Shes got plenty more in her. I have tons of info on the motor, part numbers of parts used, ect, so if you need to know anything just ask.
Bogarts - Asking $1200 obo
They have been used a grand total of 3 times!
I have the front 15x3.5 i believe and the rear 15x10 Bogarts. they will come with MT ET Drag tires, 28" diameter , and MT Front Runners, 26" diameter. Pics upon request only because they are buried in the garage, but we all know what bogarts look like.
Stock 05-09 IUP Steering Wheel Brand new in box - $150
GT500 SC tank with cap - $25
Cobra Jet Front Springs - $20
Stock Cams - $50
Upper Front grill with Fog lights and bulbs. there are small holes for an overlay grill already drilled in, perfect for not messing up your factory grill - $40
Lower Grill, Holes Dremmeled out for better airflow over a larger heat exchanger - $20
Stock Prop Rod - $5
Stock UCA - $20
Stock Water Pump - $20
Stock Panhard bar - $15
Stock Rear Springs - $20
Stock Mufflers - $30
Stock Fuel Rails - $25
Stock Windshield Washer Tank - $10
Stock Shocks - $20
Stock Struts - $20
Stock Radiator/Swaybar Support - $30
Stock Passenger Headlight - $30
2 Sets of Stock Fog light bulbs - $10 each
2 Sets of Stock Headlamp Bulbs - $10 each
Stock Dark Charcoal A-pillar - $20
99-04 Stock Grill - $20
99-04 Stock Airbox and tube - $20
99-04 Stock Shocks - $20
99-04 Stock Struts - $20
99-04 Stock Springs - $20
Manley Rods
Cobra Crank
ARP Everything
Stock Cams - $50
Stock Prop Rod - $5
Stock UCA - $20
Stock Shocks - $20
Stock Struts - $20
