Ok so this is my first time trying anything with electrical. I have the dual Aeroforce gauges and have had the 2.5 boost (requires 5v) and A/F ratio sensor (requires 12v) laying around. So i did research and read that I should use the add a fuse to get voltage for the sensor but I could not find a empty fuse slot that provides 12v during run. So I decided to probe around. With the picture on the left I found 14v and with the picture on the right I found 3v (but it changed every time I checked it).
My question is can I use either of these for the two sensors?
