i start the car everything is fine and randomly it will die on me while idling not all the time though
i try to start her up again and it throws two codes p1233 fuel pump driver module disabled and p0190 fuel rail pressure s (frp-a) ck t
i go into my truck disconnect the harness from the fuel pump driver module wait a few seconds plug it back in car starts right up drives fine all day codes go away until it happens again a day or two later....... does this mean my fuel pump driver module is going bad .....i researched other forum and read that boost-a-pumps kill your fuel pump driver module over time ....is this true?
i know its not my fuel pump because i can hear it every time i turn the key onto the on right position with codes or no codes
