Heat the bolts with a propane or mapp gas torch, as mentioned earlier. Its the single most effective way to burn the factory locktite. A few minutes of heat and the bolts will turn right out. IF you were to cut the bolt heads, now your stuck trying to figure out how to get the still locktited bolts out of the flange, and IF you were to cut the driveshaft you would still have to heat the bolts to get them out of the flange.
