Pro-Formance Specialties in Rochester, NY dyno testing our 360 cubic in small block Ford. This is a 302 based stroker set up for nitrous oxide. Dyno pulls are on a Land and Sea dyno with 32* of timing, 9 heat range plugs, sunoco race fuel and naturally aspirated. Also running the engine through the Dynomax Bullet mufflers to get a more accurate reading.
Engine made 605.8hp @ 7500 rpm and 453 ft/lbs of torque @ 5,200 rpm. The torque held fairly steady until about 7,200 rpm.
Remember, this engine is built specifically for use with Nitrous Oxide. We made these dyno pulls without it. If you are good at math we should be spraying about 400hp worth of N2O on top of these #'s.
