Please do ask for individual parts...selling whole car. Front End damage. Great donor for kit car, upgrade your six cylinder or existing SN95 Mustang gt.
Replace that worn engine and lousy t-45 transmission.
Engine has an after market BBK 78mm throttle body with plenum, 30lb. injectors, Comp cams 268 extreme cams, Comp cams valve springs, seats and new valve seals. The block is from a 98 stang with 50K miles and the heads are PI giving the motor 10:1 compression. Also included is an 04 Cobra mass air meter & SCT tuner with a $750.00 Dyno tune from Real Speed Automotive for this motor on it! The car made 278 rwhp on a mustang dyno...about 306 rwhp on a dynojet dyno. Motor runs very strong!
Seats were damaged by towing company.
8.8 rear 373 gears. 2004 Cobra brakes.
Tremec 3650 with 50K, King Cobra clutch & Steeda shifter.
The motor work, seals, gaskets and clutch were done less than 6 months ago.
$2700.00
$2700.00
