89 coupe
paint is 2 years old it has a 5.5 in extended cowl hood
interior
full 10 point with window net will cert for 8:50's
10 gallon fuel cell welded in 2 spare tire well
brand new grey carpet
gery interior
center console with painless switch panel
2-jaz racing seat with g-force 5 point harness
everything gutted under the dash(neatly nothing was cut)
rear seat delete
fuel system(brand new not installed yet)
holly black pump
8an twistlok hose
aeromotive carb regulator
fram fuel filter
front suspension
granatelli tubular k-member
geanatelli tubular a-arms
flaming river manual rack(quick ratio)
bbk c/c plates
ground pounder coilovers springs with 90/10
manual brake conversion
crooss drilled rotors with extended studs
engine bay is smooth
rear suspension
upr full drag suspension
double adj upper
single adj lowers
anti roll bar welded in
motorsport c springs
full length sub frame connectors
upper n lower battle boxes
rear end
8.8 31 spline c-cliped axels(4lug) with extended studs
axel tube are pinned
spool
4:30 gears
t&a girdle
wheels
4 15x7 weld draglites
PRICE IS $7000
ALSO HAVE A COMPLETE 10'SEC DRIVE TRAIN 4/SALE & A TON OFF PARTS....
EMAIL ME @ THEMISERY666@AOL.COM OR CALL 646-529-6423 FOR PIC'S & MORE INFO....
interior
gery interior
rear seat delete
holly black pump
8an twistlok hose
fram fuel filter
front suspension
bbk c/c plates
rear suspension
double adj upper
single adj lowers
rear end
spool
4:30 gears
t&a girdle
wheels
PRICE IS $7000
