JW SBF bell
JW case
JW roller tail housing
10 disc clutch drum
Ringless input shaft
Roller bearing aluminum gov support
Pro brake
1:80 straigh cut 1st gear set
Duel ring servo
Finned deep cast aluminum pan
Strange hardened yoke for roller tail housing included (not pictured)
Lokar locking quick release dip stick tube included (not pictured)
Hurst pistol grip quarter stick w/cable included.
5 passes since freshened, works perfectly, needs nothing.
Bolt together Neal Chance converter also available. Set up for 8.2 deck SBF. Has optional 10 leg diode and optional billet stage 5 stator, and std stage 4 stator goes with it. $4300 obo for for all of it
Acell Gen 7 DFI
FJO Wideband w/Controller
All Sensors
Pro Key
Accell Dual Sync Dist
Setup for SBF
Has a Blower tune in it and setup for 160# injectors
Like new condition,Barely used..
$1,300.00 Takes it..
Hellion Racing 1"3/4 Turbo headers for 351W based engines
3" V bands
also have 2.5" Vbands
New never ran.
Asking $800.00 w/ Assorted 45* / 90* 3" pipes and 5" piping for Down pipe and t6 Flange w/ 3" down legs
Turbonetics Y2k 91.5mm Turbo
1.08 hotside
4" inlet
5" outlet
Polished Coldside
T6 open housing
Ball Bearing
Minimal use
Asking $975.00
Precision PT 2400 Air to Water Intercooler
Custom Made to fit under the pass side dash of a fox body
4" V bands
1" 1/4 water bungs
Aluminum Piping from turbo to I/C and I/C to T/B.
Asking $2,000.00 or best offer
418 Windsor
Built for Boost
1969 Half Filled Block
Scat Steel Crank
Scat 4340 H beam Rods
Probe 22cc Dish Pistons
Hell Fire File Fit Rings
Probe Main Girdle
ARP Main Studs
Melling HV Oil Pump
ARP Oil Pump Shaft
ARP Head Studs
Pro Top Line 230cc heads
Crane Magnum 1.6 Rockers
Cam Motion Solid Roller Cam
7qt Moroso Oil Pan
Edelbrock EFI Spyder Intake
Edelbrock Fuel Rails
Wilson Manifolds Rear Facing Elbow
AccuFab 90mm T/B
Bosch 160# injectors
Oil Galley Restrictors
Screens in Oil Galley
Billet Timing Chain and Gear
Cometic MLS head gaskets
B&B Rocker Girdle
Freshened up with 800 easy street miles on it..
Asking 4,500.00
306 Stcok Block
12.5 to 1 compression
TRW dome pistons
351w Football rods
Stock redone Crank
O ring Deck
Canton 7 qt pan
Canton Pick up
MVH-98 oil pump
Solid motor mounts.
Asking 500.00 or best offer
Have pics of all parts or come see them for your self.
These are all high dollar parts ,no junk.Selling everything getting out of racing for a while.
Thanks
You can reach me at 1-845-4one 8-7 zero 44. call or text
JW case
10 disc clutch drum
Pro brake
Duel ring servo
Acell Gen 7 DFI
All Sensors
Pro Key
Setup for SBF
3" V bands
New never ran.
1.08 hotside
4" inlet
5" outlet
Polished Coldside
T6 open housing
Ball Bearing
Minimal use
Asking $975.00
4" V bands
1" 1/4 water bungs
418 Windsor
Built for Boost
Scat Steel Crank
Probe Main Girdle
ARP Main Studs
Melling HV Oil Pump
ARP Oil Pump Shaft
ARP Head Studs
7qt Moroso Oil Pan
AccuFab 90mm T/B
B&B Rocker Girdle
Asking 4,500.00
306 Stcok Block
TRW dome pistons
351w Football rods
Stock redone Crank
O ring Deck
Canton 7 qt pan
Canton Pick up
MVH-98 oil pump
Solid motor mounts.
Thanks
