SCT's Big Air series of MAF meters are purpose-built for the most powerful Mustangs who have pushed their factory MAF sensors to their absolute limits. These 90mm MAF's are able to support up to 625 horsepower when used with a centrifugal style supercharger and up to 700 horsepower with roots-style supercharger systems.
Quality Construction
Each MAF is machined from high-quality billet aluminum that can handle the massive airflow demanded by high-horsepower modifications without becoming heat-soaked.
Accurate with Large Range
The new sensor has near-OEM functionality that keeps your Mustang or Lightning drivable at low speeds, while getting you accurate readings when you floor it. The BA2600 is a direct replacement for the stock MAF on 2003 to 2004 Cobras and 2000 to 2004 Lightnings, but won't "peg out" when you bring all of the horses to bear on your highly-modified engine.
Will also Fir Custom Applications
This MAF can fit other Ford vehicles, but may require extensive modifications. This MAF can be set up to work in both blow through or draw through configurations.
Tuning:
SCT's Big Air MAF requires custom dyno tuning to prevent engine damage and maximize performance.
