<A href="http://www.linkconnector.com/ta.php?lc=000015000012004403&url=http://www.stage3motorsports.com/product/BMRFC001?meta=RSS&cpc=DOTD&cpg=11668&cpn=0" target=_blank>
2005-2006-2007-2008-2009-2010-2011 Mustang BMR Camber Bolts, Front 2 Degree Offset
BMR's 2 degree camber bolts are used for adjusting camber on the OE and aftermarket struts. The 2005+ Mustang has no camber adjustment from the factory. When lowered 1" or more, the car begins to develop negative camber resulting in premature tire wear. It is possible to gain 2 degrees of camber with one pair of bolts. If you need additional camber adjustment, 2 pairs of bolts can be used and will allow 4 degrees total.
- Item usually ships out of our warehouse in: 1-2 Days
